Hello
I used Adobe Premiere Pro 2.0 to make a detailed edit of my trip to new york, the only problem is after working on it for so long the auto saves will not open anymore. When ever I try to open the recent autosave premiere begins loading but it doesnt take as long as it usually takes, then the file appears to be loading it does about 80% and then stops and after a second or 2 the whole thing shuts down. Sometimes it just wont open all together, I have gone through all my auto saves and i found one that works but it was so old that practically none of the video is edited and my recent work is seemingly lost. There has to be something that I can do to recover it. The biggest issue is that I have alot of auto saves I hope its just an issue with that and this can all be fixed. Can someone please try and help me out.
Results 1 to 1 of 1
Exporting Premiere Pro CS4 Project - Adobe Media Encoder question
By schmickers in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jan 2012, 18:51 -
Adobe Premiere Pro CS4 Cannot Import .mp4 File
By spike32 in forum EditingReplies: 5Last Post: 19th Jan 2010, 08:15 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Edit a HD project in Adobe Premiere pro 2?
By rajaa in forum EditingReplies: 12Last Post: 21st Apr 2009, 23:16 -
Making file smaller in Adobe Premiere Pro
By JustinBaker in forum EditingReplies: 2Last Post: 18th Sep 2007, 15:07
