Results 1 to 11 of 11
    May 2008
    Any suggestions on the best way to create a movie that is playing two video streams next to each other?
  2. Member Soopafresh's Avatar
    Jan 2004
    Avisynth script.
    Left=Directshowsource("left_frame.avi")
    Right=Directshowsource("Right_frame.avi")
    stackhorizontal(left,right)
    May 2008
    That is very cool. Unfortunately, I need to see both streams so I can synch them up.
    Apr 2004
    Miskatonic U
    I do this in Vegas all the time. Just drop both clips (sometimes more) onto their timelines, then either split the screen with Event Pan and Crop, or lower opacity on the top clip so I can see both. Even better if you can use the audio to sync the clips.
    Read my blog here.
  5. Originally Posted by zapster
    That's exactly what Soopafresh's AviSynth script does:
    http://avisynth.org/mediawiki/StackHorizontal
    You did say you wanted to have them display side-by-side.
  6. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    ... so I can synch them up.
    If you need it for smth. like previewing multiangle, you can add a command for trimming the first frames in one (or both) of the imported sources in the above script, like this:
    Left=DirectShowSource("left_frame.avi").Trim(20,0)
    then adjust trim numbers in AVSP (it should generate sliders).
  7. Originally Posted by guns1inger
    I've done this many times also. Vegas can do a ton of stuff. I learn something new almost every project.
    May 2001
    I use a "half and half" video to sync up video and also to check the performance of different filter settings. This results in a normal video window with one half on the right and one half on the left, with a black bar dividing the two.
    mpeg2source("d:\Experiment\CHHTEST.D2V")
    v1=crop(0,0,350,480).addborders(0,0,2,0)
    v2=crop(352,0,352,480)
    stackhorizontal(v1,v2)
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
    Feb 2004
    Australia
    Same can be done using wax2
    May 2001
    I should have said that the right half of video 1 is shown on the right and the left half of video 2 is shown on the left.
  11. Yeah, that might have helped. Still easy in AviSynth. Before doing the StackHorizontal, crop away the right half of the left video and the left half of the right video. I'd give you a script if I knew the source resolution.
    Oh, reading a little bit up it looks like SLK001 has already given a script example for that.
