I have created a DVD using 6 episodes of a 12 episode series. I now want to do the final 6 episodes using the identical format I saved as a SVCD2DVD project. I can't figure out how to remove the existing 6 VTS files and insert the final 6 episode VTS files. Is there a way to remove files from a saved project? Thank you.
Drag them to the trash?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Right click, drag...nothing. Left click, drag...nothing. Besides, I can't find anywhere that is labled "Trash". Thank you for your suggestion, though.
I'm not at my home PC right now but there is a trash bin right above the assets section just to the right of the VTS list. You should be able to left click and drag the VTS to it, I do that all the time. You can also leave the VTS folders in place, trash the videos contained there and just drag your new assets into the proper VTS.
Dwight
- Herm Albright
Found it! It's located at bottom, to the left of the file size (Auto Fit) line. Thanks for your assistance.
Howto Reuse DVDs?
By Airjrdn in forum DVD & Blu-ray RecordersReplies: 5Last Post: 20th Sep 2009, 19:56 -
Finished my WMM project, saved as avi file-7.35gb. Now what?
By jbitakis in forum Authoring (DVD)Replies: 5Last Post: 9th Nov 2008, 13:27 -
missing VTS in DVDLabPro project
By ecc in forum Authoring (DVD)Replies: 7Last Post: 23rd Aug 2008, 04:26 -
Is It Possible to Reuse First Pass Files?
By Chakra in forum Newbie / General discussionsReplies: 22Last Post: 11th Aug 2008, 11:48 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 12:28
