I just downloaded a movie from morpheus. It is an avi file. what is the easiest way/best way to convert to vcd. I know of tmpge, but would I use the same avi file for the video and audio? Does that make sence or am I confused?
Chris
I tried, but still no luck. What codec should I be using with tmpg? When load the avi file for video, it says file not supported. I view the properties of the movie, it shows it as a windows media file and something about mp43? I read an earlier post and tried to increase the setting "directshow mutimeia file reader" in tmpg, but no luck
yep i have the sam prob man it sucks try VDUB its way better becuase some files i couldent en-code on that other app i can do on VDUB so check it out man -
:D After about an hour and a half, I figured it out. I installed the Kristal Studio Pack from the tools section and it worked!
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 21:22 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39
