Hello, I've had this problem for months and it's dirving me nuts! I can't open the audio MPEG 3 Layer on xvid.avi video. It opens the video to timeline but doesn't show audio. Some important codec is missing... I downloaded tons of codecs... ending with K-lite codec pack but nothing!
I'm trying to open thouse 350meg xvid TV series videos downloaded with torrents.
Results 1 to 9 of 9
a lot of encoders don't like mp3 if it's vbr. if it is convert it to wav and then import.
Oh thank you, i will try this out soon as I have time , what a great forum, i waited about 2 weeks for a answer in other forum and noone still didn't reply.
Edit:
"1: start - settings - sounds and multimedia devices - hardware - audio codecs - lame - remove
and then re-install lame ACM."
Hmm, i don't have that directory, i am using XP. I go Start- control panel - Sound speech and audio devices - hardware and there isn't LAME.
There's "Audio codecs" and "legacy audio devices" and some other unimportant stuff. (notaudio) like "Legacy video capture devices" , am i in the wrong place? I installed all the three codecs you gave me, still no good...
Well, if i use virtualdub to save it to wav, it opened it nicely on the timeline for one of my videos
but it gets my video out of sync... because the audio comes like 1 sec longer then the video is... -
Did you actually install LAME ? There is an inf file in the LAME folder that needs to be installed.If you did install it then you will see LAME ACM MP3 in the Add/Remove list.
Try loading the video into AVI Demux. When it prompts to build a Time Map, answer Yes/OK. Set the audio type to WAV PCM, then click on Audio -> Save and save a new WAV file (don't forget the file extension in the name). Load this into Vegas and see if you still have sync problems.Read my blog here.
I cannot open an AVI file in SONY VEGAS 10... it says I need a codec?
By daniel827 in forum EditingReplies: 1Last Post: 25th Oct 2011, 10:09 -
Vegas rendering to x264 - first 1-2 second missing
By shun in forum EditingReplies: 2Last Post: 22nd Jul 2010, 05:14 -
Sony Vegas Movie Studio 9 media generator missing.
By ahgan84 in forum EditingReplies: 6Last Post: 6th Apr 2010, 20:38 -
[Sony Vegas] editing custom codec'ed videos
By Louie413 in forum EditingReplies: 4Last Post: 20th Feb 2010, 11:39 -
Codec missing
By breeze9 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2008, 21:08
