Hi,
Have just donated my £20 and tried to register this program, I have entered all details emailed to me and when I come to finsh registering I enter my name in the 2nd field box and then nothing happens, box dissapears and thats it,
Someone help please
	Are you running Vista? Dwight
 "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
 - Herm Albright
 www.martialconcepts.com
	hi having the same problem with my father in-laws installation on vista 32
 any help would be appreciated
	https://forum.videohelp.com/topic324278.html#1776530
 This is specifically addressed on the page where the program was downloaded from.Dwight
 - Herm Albright
	I had the same problem today and re-installed avoiding installing to the standard c:\program files... and installing to c:\svcd... instead and all was fixed
	sizethurman & jeeba: you sorted? SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	I had same problem - i then left pc running and returned 1 hr later to see I could reload the registered version! good luck with it
  DVD Flick DisappearsBy Perco in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2012, 08:54
  After Effects: Text Disappears..By Coldkilla9 in forum Newbie / General discussionsReplies: 1Last Post: 29th Oct 2011, 15:09
  Desktop background disappears in xp...By pinetop in forum ComputerReplies: 9Last Post: 19th Jul 2010, 02:05
  Audio Disappears..By Hairykiore in forum Video ConversionReplies: 1Last Post: 25th Feb 2010, 19:28
  iTunes playlist disappearsBy jyeh74 in forum Off topicReplies: 0Last Post: 18th Jan 2009, 02:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
