I read somewhere that this is just a value set somewhere in the data stream
If so, it is possible to change the default aspect ratio of wmv without re-encoding it?
(those files specially were 16:9 in the raw avi format, but after the compression to wmv, since i didnt have that option to set in the encoding program, they start as 4:3 now, and people look unnaturally tall and thin :> )
	Since your original is 16:9, you can set a flag to the video to project as 16:9. I do not know any free software, but DVD Remake can do it for sure.
 It will not re encode your file, just change IFO file.
 You may be able to do it in IfoEdit, that one is free, but I am not sure about that one.
	DVD Remake seems to be more targeted to DVD editing, you sure it can works with .wmv?
	You are right, missed the part about wmv. Remake will work on DVD files.
 I thought you want to make a DVD.
	I'm not sure if it's possible to change that flag after the fact (could change how it's supposed to be encoded).
 I do know that if you had encoded with WME you could have set the aspect ratio. 1st you would edit the encoding profile, on the "Compression" pane, to "Allow non-square pixels"; this will un-grey (activate) the Pixel Aspect ratio settings, on the "Video Size" pane.
  Movie_LeftEye.wmv + Movie_RightEye.wmv + Polarized glasses = ?By barelief in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Nov 2011, 16:45
  combining WMV movie clips into one WMV clipBy blkwht240 in forum EditingReplies: 3Last Post: 5th Feb 2010, 01:41
  Basic questions - PowerPoint to WMV to connect with AVI files to make DVDBy epotereiko in forum Newbie / General discussionsReplies: 0Last Post: 20th Apr 2008, 13:56
  How to convert wmv clip so its properties match other wmv clipsBy sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16
  .flv to .wmv or wmv. to mpgBy LITEONDVD in forum Video ConversionReplies: 5Last Post: 29th Jul 2007, 19:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
