Quicktime files ext mov always hangs my machine and sometimes I have to warm boot. I had installed quicktime player and then uninstalled it. Now using quicktime alternative.
I wish to uninstall all the video and audio codec with such softwares and install Just one Klite mega pack and VLC.
Is there any software which would uninstall all the remnants of left codecs ?
Results 1 to 9 of 9
maybe you are right ? but the core question is still how do I uninstall all the video codecs on my machine and then install selectively.
Later, I can install softwares one by one as I play swf, flv and quite a diff file types. -
Read my blog here.
Start with > http://support.microsoft.com/default.aspx?scid=kb;en-us;899113
And then cross fingers.
It be a better idea to reinstall the os, make a backup image after all system drivers are installed and system is running fine ... then you can do what you want knowing the backup image will save you having to reinstall the os all over again.
As for your last question.
Only install those you need, when their actually required ... leave codec packs out -
If you want a lot of audio and video codecs in one package install ffdshow. It's far cleaner than codec packs like KLite. Rather than a collection of unrelated and often conflicting codecs and filters, ffdshow is basically one big codec that handles all different kinds of audio and video. It is easy to enable or disable individual encoders and decoders within it, and it installs and deinstalls (should you ever need to) cleanly.
How to trace original ip address of email sender?
By skorpinok in forum Off topicReplies: 1Last Post: 24th Jan 2012, 00:28 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Some Problems in PgcEdit --Trace Mode--
By dashali in forum Authoring (DVD)Replies: 1Last Post: 22nd Mar 2010, 16:28 -
How to trace an IP address ?
By susie in forum ComputerReplies: 11Last Post: 21st Dec 2007, 10:08 -
Video Files have a trace effect
By pbisaillon in forum Authoring (DVD)Replies: 7Last Post: 18th Oct 2007, 13:05
