Hi all,
I've stumbled across AVIs that were encoded with XviD, yet manage to be of various sizes. However, I can't seem to change the resolution when I try to encode an AVI. Does anyone know how to define a particular resolution with XviD?
- Justin
You need an editor with a resizing filter. Try VirtualDub, AviDemux, or AutoGK. All free.
What program are you using to do the encoding? In VirtualDub, use the 'Resize' filter if you want a different framesize, then encode. The Xvid codec itself will take most any framesize you throw at it. (Within a few rules.
Under Advanced Settings you can set various resizing methods. I usually set a fixed width and let AutoGK work out the rest. Crtl+F9 brings up the hidden settings panel, which gives you even more options, including cropping. There is no way to change the type of resize performed however.
Read my blog here.
Re-Encoding 720p H.264 MKVs to 400p XviD AVIs?
By Kid Ryan in forum Video ConversionReplies: 6Last Post: 27th Feb 2011, 13:01 -
Simple Script to Prepare Your DivX/Xvid AVIs for Transcoding
By Soopafresh in forum Video ConversionReplies: 17Last Post: 13th Jul 2009, 21:30 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
MpegStreamclip 1.9.2 weirdness with XVID avis
By terryj in forum MacReplies: 2Last Post: 10th Oct 2008, 19:33 -
Resizing AVI and changing bitrate using Virtualdub and XviD
By mlwitchking in forum EditingReplies: 7Last Post: 27th May 2007, 15:45
