I recently purchased some supposedly official CD-R acetates from the mid 90's and I was wondering if there were a way to check and see if the discs were actually burned back then or if I have fakes. Is there a program that can tell when certain CD-R's were manufactured or when the discs were burned?
Unfortunately when I look on windows explorer, I get the same date for all discs, no matter what I put in. Can anyone help?
	anyone with a cd-r drive can make an exact 1 to 1 bit accurate copy. no way to tell the difference. hope the cd-r's were cheap. --
	I'm well aware of that but it doesn't mean that they can do an accurate visual representation of what the promo CD-R's look like.Originally Posted by aedipuss
 That's why I was wondering if there were a way to find out when a particular make of CD-R was manufactured OR when this particular CD was burned.
	there are programs that will read the atip of the cdr. date of manufacture is not one of the things in there but manufacturer, dye type, and rated speeds is usually included. that might give you some window of time if you can get data to match up with the atip info.
 alcohol 120%, or something like cd-r identifier should work.--
	another good tool to try is nero info tool.
 ftp://ftp6.nero.com/tools/InfoTool.zip--
  setting MKV dateBy larryc in forum Video ConversionReplies: 17Last Post: 17th Oct 2017, 15:42
  Removing the fied dateBy evvivame in forum Capturing and VCRReplies: 0Last Post: 27th Jun 2011, 04:09
  Time/dateBy whitek75 in forum EditingReplies: 3Last Post: 10th Mar 2011, 12:50
  Capturing with Date CodeBy scormodo in forum Capturing and VCRReplies: 2Last Post: 13th Mar 2010, 13:29
  Date & TimeBy fzf5bl in forum MacReplies: 1Last Post: 8th Nov 2007, 03:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
