I've been trying to figure it out, how can you find what video card is on a laptop? I have nvidia, but not sure which one.
thanks
winxp - 3.06 -
thanks, but forget it. I should have googled hours ago.
duhwinxp - 3.06 - -
Though you probably found the answer, most times just look to your display settings under 'adapters'. Once you have the model of the video card, you can go to the chipset manufacturer and get the latest drivers, very often much newer than the ones from the laptop manufacturer.
For Nvidia: http://www.nvidia.com/Download/index.aspx?lang=en-us
Or ATI: http://ati.amd.com/support/driver.html -
Or you can use software such as SIW. It will also give you much more information.
http://www.gtopala.com/Google is your Friend
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 03:37 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
Do I need a Video Card or a Capture Card...
By gnomeChomsky in forum Capturing and VCRReplies: 14Last Post: 18th Jan 2008, 22:26 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
