When I imported a wav file into EditStudio, the icon has a question mark and highlighting it shows it has zero duration yet it plays fine (and displays its duration) in VLC Media Player, Foobar, and Audacity (which I used to export it after cleaning it up). I re-opened it in Audacity and exported it again. Same result.
I'm talking about importing WAV audio for editing. EditStudio does not take AC3 as imput. I wonder if one of the plugins has gone bad because the previously working audio in another project no longer works either.
Yep, you need a wave file for editing. But is your wave file the correct bitrate, etc. for editing? For example, if you're editing DV-AVI files, the wave needs to be 48kHz, 16-bit stereo. EditStudio may be kicking the file back due to incompatible bitrate. 12-bit, 4 channel audio, often found on camcorder default settings, can be troublesome to certain editing programs...
It is indeed 16-bit, 48Hz. As I mentioned, another project I was working on with WAV files, no longer plays the audio so I have to check and see if its a preference thing or reinstall it.
Editstudio Pro 6: Effects problem
By Sillyname in forum EditingReplies: 0Last Post: 14th Aug 2010, 19:59 -
EditStudio Pro 5
By Illusionist in forum Newbie / General discussionsReplies: 6Last Post: 18th Jul 2008, 17:25 -
EditStudio PRO version 6
By Mariot in forum Latest Video NewsReplies: 1Last Post: 24th Mar 2008, 22:43 -
editstudio 5 - now from mediachance, anyone using it?
By aedipuss in forum EditingReplies: 5Last Post: 14th Feb 2008, 15:46 -
Problem importing video into VirtualEdit
By acid_burn in forum EditingReplies: 3Last Post: 23rd May 2007, 10:07
