Hi. I need to make some CD copies. I duplicated the original CD using the Finder and burnt directly to disc also using the Finder. The result wasn't playable on any standalone CD player. The duplicate files were converted to AIFF files it seems. These are spoken word files so about 40 MB each. If I use iTunes to convert to AAC format I think I can then burn them to make playable CDs but I lose a lot of MBs and so quality in the process. Is there a simple quick wayto do this using ffmpegX or something else?
Thanks in advance
Subm
The audio program sox can convert AIFF to WAV. Go to:
http://sox.sourceforge.net/
This program does not have a Mac version, so if you are only interested in something on Mac, I can't help you.
If all you want to do is make a copy of a cd (no re-encoding, no editing, no other mods of any kind in between), then why not just use Toast?
Actually thanks for the input but I've worked out how to do it using iTunes. What I was doing wrong was: burning the files as if they were data files (default Finder burning). I think iTunes makes the AIFF files into a playable audio CD without having to convert to AAC which would mean a significantly smaller lower quality disc. I don't have Toast (yet).
thanx anyway.
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 15:57 -
AC3 -> AIFF, and AOB -> AIFF for Jaguar 10.5.6?
By DeadSirius in forum MacReplies: 4Last Post: 29th Dec 2008, 14:54 -
Burning engine for audio CDs
By dadrab in forum ComputerReplies: 13Last Post: 29th May 2008, 15:23 -
aiff to mp2 audio conversion problem...
By huatnee in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2007, 11:52 -
problems Muxing M2V and Aiff files to MPEG2
By bbaddorf in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2007, 15:14
