Is there a way to take a DVD file and resize it to vcd size ie (352*288) but keep it as a DVD file - if that makes any sense? To explain things more clearly, I am trying to take two frames from two video files, one compressed and one original. The original being the DVD file and the other being a VCD file compressed from the original, but the problem is the two are different sizes. Any ideas would be much appreciated. Thanks![]()
i'm a n00b but i've been fiddling with TMPengc
try the vcd profile to decrease the size. i dont think thats what you want though is it?
in the extras folder of where you installed TMPengc there is a profile called unlock. it unlocks ALL the settings (natch).
load your DV profile, then the unlock profile. you now have a fully editable DV setting. change the rez, sound etc...
...but this is theory. i dont know about it working, vcd compatibility etc etc.
just an ideaBeer gives courage wings
Resizing video resolution and video quality
By Timex in forum Video ConversionReplies: 13Last Post: 23rd Aug 2011, 22:08 -
Resizing: Resolution and Aspect Ratio
By roflwaffle in forum Video ConversionReplies: 7Last Post: 9th Apr 2011, 08:25 -
Questions about resizing/rescaling/changing the resolution....
By divxmpegjpeg in forum Video ConversionReplies: 0Last Post: 14th Mar 2010, 14:07 -
What is the mathematical formula to figure out the right resolution when resizing?
By Newtype in forum Video ConversionReplies: 10Last Post: 8th Feb 2010, 17:11 -
Resolution Resizing & Using Filters
By OllyPomm in forum Video ConversionReplies: 9Last Post: 25th Nov 2009, 22:21
