I have a conventional mpeg2 dvd containing 43 chapters that I need to split into 11 files. Each point where I want a file to end is exactly at the end of one of the [s:f1e0c4a0d0]titles[/s:f1e0c4a0d0] chapters*. What tool might do this the easiest?
I own Womble MPEG Wizard, which will achieve the desired result, but not easily. What will let me do this simply, easily and quickly?
* Edited.
DVD Shrink in reauthor mode allows you to chop parts of a DVD out. You'd have to do it 11 times for 11 output files.
DVDFab HD Decrypter can also rip based on chapter breaks.
If you used DVD Shrink, you could do it all in one pass and get a new structure with 11 titles, then use VOB2MPG to extract the titles.
However none of these solutions will be much quicker or easier than simply exporting 11 times from Womble.Read my blog here.
Extract chapters to separate MPEG files?
By Figge in forum Authoring (DVD)Replies: 9Last Post: 9th Apr 2018, 15:38 -
How To Rip DVD To Separate Chapters?
By Nitro89 in forum DVD RippingReplies: 7Last Post: 14th Apr 2011, 11:06 -
How to get separate VOB files?
By rmdeboer82 in forum Authoring (DVD)Replies: 14Last Post: 18th Aug 2008, 10:37 -
Can't switch between separate dvd-files
By SirTarhan in forum Newbie / General discussionsReplies: 8Last Post: 27th Mar 2008, 03:16 -
Batch joining into separate files
By Bratac in forum EditingReplies: 0Last Post: 20th Aug 2007, 07:02
