I wanna record some songs,i have a microphone...I just need a basic studio and a little help on how to use it,i wanna add the beat on a track,and then sing with the beat as it's recording....then make a new track and on THAT track add some clips or more vocals and then add the end blend it all together onto ONE TRACK in Mp3 format,I'd appreciate some help
thanks
thanks,I will try it and let you know,(if you want) Thanks for always bein first on the scene to help out
Hey i downloaded that program but now i can't seem to figure out why my mic wont work,I tried all different programs so it isn't the program,Do you know of any settings i may have missed,cause i did check a few settings =\
Double-click on the Speaker icon in the system tray to open the properties sheet. Probably called Master Volume. Click on Options>Properties. Either click on the Recording radio button, then make sure the Mic and Line In inputs are ticked, or pull down the Mixer Device drop down and select the Input device. Again, make sure Mic and Line In is ticked.
Click OK, and you should not see the Recording properties sheet. Make sure Mic Volume is ticked. If you don't, try Line volume.
All of this assumes you have the mic plugged into the right jack etc.Read my blog here.
Thanks,i ended up figuring it out right after i made the last post sorry,Now i am having issues geting my voice higher,when i sing with the beat....the beat is way louder and you can barely hear my voice
You have a few options :
First, make sure you have the input levels correct for the Mic so you are getting a good signal without distortion.
Second, every track in Reaper has it's own volume level, so you can boost just the vocal track
Third, you can add a volume envelope to the track, and by adding points you can vary the volume at different points in the track as necessaryRead my blog here.
How do I Rip sound effects and music separately?
By tapir in forum DVD RippingReplies: 9Last Post: 19th May 2010, 01:04 -
free sound effects , laser , explosions ect?
By Bansaw in forum AudioReplies: 9Last Post: 28th Nov 2008, 12:24 -
"MPEG Video Wizard DVD" Effects and Sound Editing Results?
By cyberboy in forum EditingReplies: 1Last Post: 8th Jul 2008, 00:39 -
Vegas Movie Studio 8 Platinum Music/Sound effects
By Nuke Shower in forum AudioReplies: 3Last Post: 21st Apr 2008, 00:58 -
Adding audio as background music whilst listening to the main sound
By Mrwoo1234 in forum AudioReplies: 3Last Post: 29th Dec 2007, 09:30
