hi
can you please recommend some freeware soft to build www sites....
some good easy for intermediate user..thanks
I would say notepad if you are really intermediate.
If you more of a beginner and need a GUI, go with something like coffecup -
Why would you want to use notepad over coffeecup or any text editor made for code?
Notepad is fine for simple quick edits but the tools available in any good text editor is going to trump it. The highlighting alone is reason enough to use them.
Other than coffeecup there is Notepad++ ... -
Because it's there already? If you're a decent coder, notepad if good enough? "Best" is very subjective? Take your pick.Originally Posted by thecoalman
Besides, I already mentioned (and linked) coffeecup. -
Well like I said the highlighting is worth the price of admission alone if anything. I rarely use the other features excepy maybe quick insertion for links and images and a few other major tags. Even if you're debugging errors you have the line numbers at a glance. For that matter you can pick errors up because the highlighting will break. Guess to each his own.
thanks for replies, i did not mean text coding editors...i mean simple drag and drop making website tool
any freewares available like this -
Coffeecup has a WYSIWYG option, not sure how well it works because I don't use it. If you look at the top of my screenshot you'll see the tab named "code editor". there's two additional tabs that I don't use so I have them removed in options. One is for a preview and the other is for the WYSIWYG option. You can switch between the three modes by clicking the tab.
Just to add I downloaded the free version once and frankly I don't think there is much difference between it and the registered version. Generally free versions have some major feature missing or they are really hobbled but I really couldn't find anything missing.
What is the latest best freeware for making copies of my own DVDs?
By govtdog in forum DVD RippingReplies: 5Last Post: 22nd Jan 2012, 09:50 -
Freeware for making music videos?
By muffinman123 in forum EditingReplies: 4Last Post: 21st Sep 2011, 05:44 -
Making CD-R compilations: Best mp3 splicer freeware/cheapwear suggestions
By Krelmaneck in forum AudioReplies: 26Last Post: 2nd Oct 2009, 01:50 -
is there a freeware tool for making an image of my c drive?
By surfmonkee in forum ComputerReplies: 17Last Post: 10th Nov 2007, 21:01 -
ARE there web-sites that lease, and i join and use their software
By Lennoxtown in forum ComputerReplies: 1Last Post: 13th Aug 2007, 07:55
