Hello All,
I'm new to this forum and also this is the first post.I'm trying to burn of th movie.I usd to burn my all DVD movies using NERO 7.These day's I'm gtting this error for every file.
the directory you have selected already contains VIDEO_TS directory.All IFO,VOB and BUP files will be deleted.Do you want to continue?
Please do help me....
Results 1 to 20 of 20
That sounds like you are doing more than just burning a DVD. If you are using Nero to encode and author a DVD file, then that error is saying that you want to put that file in a directory or folder that already has a VIDEO_TS folder in it. If so, either delete the old file or chose a new directory.
BTW, 'burning' is only the process of creating the DVD media disc itself. A DVD file is usually first 'encoded' or converted from other formats, such as Divx/Xvid, then 'authored' to the DVD format, then finally 'burned' to disc. All separate operations, though some software combines them under one program.
And welcome to our forums.
I 'm just trying to write files with extensions(.avi).Please help...
What is not working? What video files do you have? vob,ifo,bups?
I tried to put in seperate folder,still getting the same error...
It is very difficult to help you, since you are so unclear about what you are trying to do. You mention files with .avi extensions. AVIs are not DVD compliant. You were asked if you were only trying to burn a DVD or also encode video to DVD compliant files. Which is it? Both? You were instructed to use ImgBurn instead of Nero for burning. Did you do that? We can't help you unless you help us help you.
To help you, please tell us the following information:
1) What are the source files you are starting with?
2) What is the final result you are seeking?
For example, "I am starting with Divx .avi, and I want to produce a DVD that will play in a standalone player."
Or, "I already have DVD-compliant files, and I just want to burn that result on a DVD."
So far, you've only given us snippets of information, not all of which makes sense. So, rather than saying "It doesn't work, please help!" tell us what "it" is, and then maybe we can help. -
Okay,to be clear.I have following Input and need respective output.
1.I have a .AVI file(as Input) needed to burn DVD for standalone DVD players.
2.And when I try to do with Nero 7 taking .avi files added and click on Burn I get following error message
When I say yes, it writes but cannot play on standalone DVD player.I cannot see any contents on disc itself,usually when I burn the Disc automatically it exists out(mean disc comes out when finished burning).
Hopefully,I'm so clear.
Note: The .AVI files I'm writing are downloaded movie files.
Thanks. -
I'm getting exactly the same message, I'm trying to get an avi files (a film) onto a dvd so i can play it on my dvd player. I have downloaded the imgburn and when i go to the chose file bit it wont let me chose it cos it doesnt support avi. please help me, i only know basic styuff and this is confusing me
@coinsdrop : you have already converted an avi to DVD, and are now trying to convert another one to the same location. Nero is telling you that if you proceed, the files from the old DVD will be deleted to make room for the new one. If you have already burned the last one to disc, you can say yes and create a new one. If not, say no, and choose a new location on your HDD.
@NaomiC : you have to convert your avi files to the DVD specified format first. Imgburn will not do this for you. Try DVD Flick or Favc. Once you have a video_ts folder, you can use Imgburn to burn this to disc.
To both of you I suggest the following :
1. Ditch Nero. It is garbage.
2. Do some reading. Start with "What is DVD ?' (top left corner) then some of the basic authoring guides.
3. Learn a simple converter such as DVD Flick or FAVC.
4. Always use Imgburn
5. Get a Divx/Xvid capable DVD player or WD TV and save yourself the need to convert your files.Read my blog here.
Thank you muchly, i am doing what you've told me now, so fingers crossed that i can actually work it all out, if not i'll message again :P
does this mean that i can download any sort of file and it will sort it out for me ready to burn to watch on a dvd player, cos i have had so many files i havent known what to do with, ialways tried to get avi files cos the rest confued me
It will convert many formats. Generally, if you can play it in Windows Media Player, it will convert it. However don't expect miracles if you are downloading you tube clips and hoping for DVD quality . . . .
Read my blog here.
okay, i think i've cracked it, finally, i'll know in a bit when its finished and i can try it, it seems like a very long process though, i might try and burn it from the flick thing and see how that goes, but i'm sure i'll get faster as time goes on, thanks muchly for ya help
Error messages burning data DVD using Nero version 6
By craigsb in forum ComputerReplies: 6Last Post: 27th Oct 2011, 09:12 -
Burning DVD+R with Nero 7
By solarblast in forum Authoring (DVD)Replies: 6Last Post: 24th Aug 2010, 05:17 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Error, after burning a dvd with nero
By Remyisme in forum Newbie / General discussionsReplies: 13Last Post: 27th Sep 2008, 02:11 -
NERO gives me error message when burning DVD
By qwazi in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2007, 01:01
