Hi.
I'm trying to convert a .mkv file to dvd. I can extract the components of the .mkv, and am left with a .h264 video stream, a .ac3 audio stream, and a subtitle file.
Here's a screenshot of what MediaInfo has to say about the file.
http://www.etherealryvius.com/pissingmeoff.html
When I import the .h264 stream into Tmpgenc Xpress 4.0, it lists the file run time at 5hrs., 14+mins., instead of the 1 hr., 37min. actual run time, giving me about a 10 Gb final mpg-2 after conversion.
Is this because of the high resolution of the source file? Are there any settings in Tmpgenc Xpress to compensate for this that I'm missing? Better yet, is there another program that will accomplish what I want to do?
Thanks in advance for any info about this. I've searched quite a bit, and haven't found much. Could be I'm not asking the right search questions.
occasionally larger than 255 characters
resolution won't influence running time. Tmpgenc obviously doesn't understand how to read the source video correctly, or the source is corrupt in some way, which is why tmpgenc sees it as longer than it is.
I would suggest trying FAVC or DVD Flick or ConvertXtoDVD for the conversion. All of these will preserve the 6 channel AC3 if it is compliant. You will have to extract the subtitles and make sure they are in a format that one of these will like, but otherwise they should do a good job.Read my blog here.
AVC/H.264 Blu-Ray Template for TMPGEnc 4.0 Xpress?
By CubDukat in forum Video ConversionReplies: 8Last Post: 22nd Sep 2010, 11:52 -
Video Run Time Gets Cut in half - and other conversion problems...
By scotsgael in forum ffmpegX general discussionReplies: 0Last Post: 3rd May 2010, 02:41 -
Create a streamable mpeg-4 avc in TMPGEnc Xpress?
By KingsCrown in forum Video ConversionReplies: 2Last Post: 22nd Jan 2010, 09:20 -
Can I convert BD .mt2s files to MPEG-4 AVC/H.264 using TMPGEnc 4.0
By EdinburghKev in forum Blu-ray RippingReplies: 3Last Post: 20th Nov 2008, 10:10 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37
