I live in a townhouse and my Wireless router is on the bottom floor, but I want to create a wireless environment that would allow me to use the internet on a computer we have on the 3rd floor. I already bought a wireless card for the PC, but I don't think the signal is strong enough, what would I need to get to pick up the signal. Would an Apple Airport do the trick?
Mark
	What kind of "Wireless router is on the bottom floor"?Originally Posted by Jabroni4872
 Simple solution is to add a directional antenna. You can buy repeaters for most brands but that mostly makes it easier for your neighbors to hack you.
 Are you sure the signal doesn't reach? Try moving the router around. Turn it on its side.
  Recommends: Kiva.org - Loans that change lives. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Or it might be feasible to get a wireless access point as a reapeter. I'm not entirely sure what they entail. My understanding is they act as a midpoint to boost your original transmission signal. It would be placed at some midpoint between your transmitter and final destination.
 Check out dlink or linksys and search for "extender" or "access point" to learn more.
 BUT as suggested early do a test run before buying more equipment. You may find you have sufficient range for your needs.
 EDIT - If you are using a "PC" as in WINDOWS then no do not buy anything APPLE. They won't talk to each other.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	This looks stupid but apparently works, won't cost nothing...  : http://www.youtube.com/watch?v=sUTT8wdN_VA : http://www.youtube.com/watch?v=sUTT8wdN_VA
	http://www.freeantennas.com/projects/template2/index.html for the template they use. Read my blog here.
	Just make sure you make 2 (one for the router and one for the receiving computer) 'cause it is silly if you can receive the signal but can't send the upload signal to the router.....Originally Posted by thecoalman
 Also, do not laugh, but I tried the following and it actually work.
 http://www.usbwifi.orconhosting.net.nz/
 I was able to get the signal strength from 25% to 80% from the router. The only problem is I couldn't do the same thing to the router. So I end up having a one direction communicate only.....
	That's probably the way I'd go.or looking at LAN over power and running an ethernet connection through your mains wiring.
 http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2000130294&bop=And&Order=PRICED
 You could hardwire it if you were mechanically inclined and get full LAN speeds instead of wireless speeds.
  broadcasting a wireless signalBy romanstopme in forum ComputerReplies: 13Last Post: 27th Apr 2009, 20:43
  Need to get a stronger signal - use an antenna pre-amp?By Mr. Burn in forum DVB / IPTVReplies: 13Last Post: 24th Jan 2009, 17:56
  Time TravelBy ron spencer in forum Off topicReplies: 17Last Post: 30th Dec 2008, 01:48
  how to limit speed of users on wireless network (router-lan-wireless)By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Nov 2007, 00:56
  USB Wireless lan stronger than Internal wireless?By Super Warrior in forum ComputerReplies: 11Last Post: 7th Aug 2007, 00:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
