  1. I recently had a processor go out and ended up getting some new hardware which is cool. I started to get back into working on some audio video projects and am I having difficulties. I have some DV that I shot that I am transferring to the computer to work on. I am using the 1394 port for the best quality transfer. the transfer works and the files are created no problem. I wanted to work on the look of my current video....it is a little dark so I was planning to lighten it up some. Once done I wanted to make a computer friendly version (a smaller file type compared to the AVI or MPEG sizes) for upload to the likes of You Tube or maybe some to the video iPOD. I have a Studio 8.6 Pinnacle Studios and I have used the Windows Movie Maker in the past. However, Studio 8 is giving me this scene detection error and Windows is also having its issues. For example, I import the video into Windows MM and it shows in the clips area, but when I add it to the storyboard it freezes up. I am getting similiar problems from both programs which leads me to the thought there is a single underlying problem that I don't know. I just want the high quality video to be cleaned up and then convert the file to a more friendly computer file to share. Any ideas. The current file is 348MB which is a little bit but not alot. I am running a AMD Athlon Dual core 5200. It is like a 2.7 GHZ with 2 GB of Ram. Any help would be greatly appreciated......frustration time need a break. Thanks
    Brent
    Bad area on the hard drive, maybe?
    Lots of possible problems to look for here.
    Feb 2004
    Australia
    Start from the begining and well help you locate the fault.
    As a quick Q, did you reinstall the os ?, what hardware was actually replaced ?
  4. Yeah, I ended up replacing the motherboard, the procressor, new 2GB of RAM, needed a higher output power supply, and for fun upgraded a newer video card. The only thing I had from the existing computer was the case, the burner and hard drive. I reinstalled my Microsoft XP Home because of the valiadation process. Repair did not work at first so after I made sure I had all my main files backed up, I did a fresh full install of Windows XP. I did a slew of updates and driver updates for all my items so this seems to be the last bug in the system so to speak. Thanks for the help.
    Brent
