I was wondering if the problem where the resulting encoded dvd file was larger than expected has been fixed since a few versions back? I haven't used this software in a while because of having to use dvd shrink to reduce the filesize everytime I encoded a dvd with this software.
It is better at hitting target size but problems can still pop up from time to time. The issue is really with the source files, not S2D. I have tried other encoders (CCE, etc.) on files that result over/undersize with S2D and the probelem exists across platform.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Does the program support dual core because at the moment it is only using 50% of the cpu and I'm getting 46fps.
Not yet.
I am running a Core 2 Duo, 2.33 GHz and regularly get 85fps or above. I would think you should be getting more speed from your system.Dwight
- Herm Albright
As I said, I don't really see the filesize problem as an issue only for S2D. If I get it on a high end encoder like CCE, then it's got to be a source problem.
Multi core support is, I believe, slated for a near future release.Dwight
- Herm Albright
Sounds like something is wrong there. Perhaps you don't have a multi-threaded avi or xvid codec installed?Originally Posted by Comrinec
When I run dual copies of QuEnc the total fps is typically around 130 and my SVCD2DVD throughput is usually over 70. Sounds like your installation may be relying on DirectShow instead of a native codec. I think AviDemux uses its own multi-threaded libraries which is why you still get high speed with it.
In any case, there are faster avi to dvd converters out there but SVCD2DVD is still good to have for its original purpose... making episodic dvds from mpg sources without reencoding the video.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
Problem with target filesize in xvid
By legion0 in forum Video ConversionReplies: 18Last Post: 21st Mar 2010, 23:58 -
ripping a dvd to mkv h264 filesize question
By stackner in forum DVD RippingReplies: 5Last Post: 16th Jan 2009, 17:13 -
MeGui HDTV TS to x264 mkv filesize problem
By thunder2008 in forum Video ConversionReplies: 0Last Post: 15th Jan 2009, 02:53 -
DVD is different filesize when I run it through TMPGEnc
By Salva Veritate in forum Authoring (DVD)Replies: 5Last Post: 17th Dec 2007, 18:10 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07
