OK, here is what I did.
Used VirtualDubMod to convert the file
I hit File and chose the VOB I wanted to convert
After loading I hit File Save As and named the file, and choose to save it as an AVI
I left all the default setting as is. It processed in Full processing mode
The original VOB file was approx 1 GB. The AVI I ended up with was 23 GB
The first 2 minutes or so played fine, but then it started to stutter, then go, then stutter then go, etc
I then fast forwarded a few minutes into the clip, and it started playing ok again for about two minutes, but then started to stutter again.
Any suggestions on how I can do a better job? I only wanted to convert to AVI so I can blend pieces of this video in with some others I have. I also would prefer to have a file that will easily play on Windows Media Player.
Thanks in advance
HB
Use a video compression, under video->compression. If you want small file size use divx or xvid(install the divx codec or xvid codec if they aren't in te list). If you want a format so you can easily edit the video use dv-avi (install for example the ceocida dv codec).
DV-AVI conversion to H.264 / MPEG2 - playback speed issue
By howardmg in forum Video ConversionReplies: 9Last Post: 28th Jul 2011, 00:07 -
Trouble converting VOB to AVI using Handbrake (audio issue)
By binvisions in forum Video ConversionReplies: 1Last Post: 1st Aug 2009, 04:28 -
Very Newbie Conversion -- Vob to Avi
By dadada_999 in forum DVD RippingReplies: 3Last Post: 2nd Dec 2007, 13:51 -
No video in VOB to AVI conversion
By Matt42 in forum DVD RippingReplies: 12Last Post: 24th Nov 2007, 22:04 -
M2V To Avi Conversion Issue
By R3bel in forum Video ConversionReplies: 2Last Post: 4th Sep 2007, 20:15
