Hi,
Where can I set the field order in CCE (version 2.70)???
My source video is a dv avi and is bottom field first.
I processed it through an avisynth script like this:
Code:AviSource("myvideo.avi") assumebff() separatefields() <some filtering and other processing> Weave()
I unchecked progressive frame.
When I try to play the video in powerdvd, the video is jerky. The same encoded with tmpg xpress looks fine like the source.
Progressive frame should not be checked because working with interlaced video.
AVI Field Order
By Ash McKenzie in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2012, 00:52 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
Determining field order
By dadrab in forum Video ConversionReplies: 2Last Post: 4th Oct 2007, 15:09 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14 -
Need to change field order
By Loko in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 20:32
