Results 1 to 15 of 15
    May 2008
    There's something wrong with my DVD Decrypter. Whenever I rip a dvd with it, no matter if it's an IFO file to compress or an ISO to burn onto another DVD, the video becomes all patchy with distorted boxes popping up every few seconds. I've tried uninstalling and reinstalling it a few times but it still does it. Anyone know what the problem is?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If it is a new DVD....try ripping it with a ripper that is not OUT OF DATE AND OBSOLETE. DVDDecrypter is still VERY useful....but not as a ripper of new DVDs.
    May 2008
    They're not new movies, for example I ripped the movie Seven, but what program would you recommend that can rip the movies and then be able to be compressed by autoGK?
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    use DVDFAB HD DECRYPTER to rip files to your hard drive. it's freeware.
    May 2008
    Ok, so I tried another DVD ripper called ClanDVD and I got the same problem. It can't be the DVD because it's happened on every DVD I try. So if it's not DVD Decrypter and it's not the DVD.. then what the heck is the problem?
  6. Member louv68's Avatar
    Feb 2004
    Minneapolis, USA
    Does this problem occur if you play back the "uncompressed" ripped files, or after the video is "compressed" with DVDShrink or another "video compression" software?
    -The Mang
    May 2008
    It happens on both of the, before and after compression.
  8. Member louv68's Avatar
    Feb 2004
    Minneapolis, USA
    So this is happening when you play back the "uncompressed" ripped files off the HDD too?
    -The Mang
    May 2008
    Yes it is
    May 2008
    I even ripped it as an ISO file on dvd decrypter and burned it on a dvd and it had the same problem.
  11. Video Restorer lordsmurf's Avatar
    Is it like this in software like PowerDVD, before you burn, or only on the burned copy? If hard drive playing is fine, it could be a low-quality blank DVD. If good on hard drive AND good media is used, it could be a writer issue.
    May 2008
    I just tried playing it straight from the DVD and it has the same problem, and on top of the patchy video it's all jumpy. Does that mean that my DVD drive has gone bad and I need a new one?
    May 2008
    And no It's not the DVD because I've tried more than one, and also tried them in another dvd player and it works fine.
  14. Member louv68's Avatar
    Feb 2004
    Minneapolis, USA
    It should play fine off your hard drive without macroblocking using a software player such as PowerDVD, MPC or VLC, as long as no compression is applied.
    Your pc specs are sufficient to playback DVD's with no problem. Just throwing out some ideas. Have you not defragmented your hard drive in a while? Check to see that you have DMA enabled. Got to run, but someone else can likely help you. Good luck.
    -The Mang
    May 2008
    I've come to the conclusion that there's something wrong with my DVD drive, is there anyway to fix it or do I need to buy a new one?
