I'm new to Avisynth and am doing some simple editing. I had a couple questions.
(1) When I am doing my editing of joining and cropping videos, I want to resave the output. Do I open the script.avs in Virtualdub and just capture the AVI again? If something is already compressed, is there any default setting to keep the compression the same. I am guessing I will have some loss to my video since I am editing and resaving again, but I was trying to find the best way to save the new output with less loss and keeping the file roughly the same size. Or do I just configure the compression type according to the size I want.
(2) When I capture clips with my PVR, I get the same black bars around the edges of my video. I want to create an AVIsynth script to crop out the black bars and resize my video. I also use the same AS@L5 two-pass Xvid compression and was wondering if there was any way to automate that so I don't have to always save some file as the first pass, and then save another file as the second pass to get my output. Just trying to reduce the redundancy of my clips. Thanks!
(3) What is the difference between LancosResize and Lancos4Resize?
With multipass VBR encoding you have to perform at least 2 passes. During the first pass the encoder is only looking at the video and saving information about each frame. During the second pass it uses that information to allocates bitrate to each frame to get the best quality for the requested average bitrate.
Avisynth audio editing
By Mephesto in forum Newbie / General discussionsReplies: 10Last Post: 20th Apr 2012, 00:35 -
Intuitive avisynth editing
By Mephesto in forum EditingReplies: 5Last Post: 25th Feb 2012, 09:31 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Software that export editing operation as avisynth script
By Nykoo in forum EditingReplies: 4Last Post: 3rd May 2009, 13:12 -
Lossless editing of .m2t (MPEG-2 TS) in Avisynth
By Tigon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th May 2007, 08:23
