Hey so I'm trying to rip dvd to xvid. I've been using DVD decrypter, DGIndex to separate the audio and video streams, and Vdub to encode to xvid. Sometimes though, DGIndex and Virtualdub will say that an mpeg2 file I ripped has different frame rates. Usually I will open it in DGIndex and it will say 29.70 and then again in Virtualdub and it will say 23.976. I think this is causing audio and video sync errors and I'm curious if anybody has run into this before.
Tim
	DGIndex:
 Video -> Field Operation -> Forced Film = 23.976 fps in VirtualDub.
 Video -> Field Operation -> Honor Pulldown Flags = 29.97 fps in VirtualDub.
 Neither should cause A/V sync errors with normal 3:2 pulldown flagged sources.
 VOB files often have variable frame rates, especially at the start with the studio logo, etc. This often causes A/V sync issues but can usually be used by using the audio skew setting in VirtualDub.
	Hey thanks for the reply, and that does make sense. When I preview the file in DGIndex the first couple frames it says interlaced, and then, after a couple seconds it goes to film. If I do honor pulldown flags instead of forced film would that correct the error? If not, is there any way to account for this without encoding, looking at the video sync, and then encoding again?
 Tim
	Maybe. Why don't you try it? You will probably need to inverse telecine if you do this.Originally Posted by dimtim
 You don't have to reencode again. You can remux the audio and video with VirtualDub in Direct Stream Copy mode and use the audio skew function to shift the audio forward or backward.Originally Posted by dimtim
  Audio sync issue, Virtualdub, old video clips changing frame rateBy litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 12:35
  FLV Frame-rate issueBy djsquared in forum ffmpegX general discussionReplies: 2Last Post: 9th Jun 2008, 17:15
  Bit Rate And Frame RateBy bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48
  weird TV as a second monitor issueBy pheldd in forum Software PlayingReplies: 14Last Post: 6th Nov 2007, 05:48
  Frame rate conversion by changing frame countBy asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
