    Jun 2007
    Pakistan
    i have a folder named video_ts in which the following files can be found.
    my friend told me that it copied these files from a dvd i want to burn them into a dvd with menus. is possible and how.
    Do you want to make a new menu? Then you can use tmpgenc dvd author and import the dvd.
    If it contain a menu you just can just burn the video_ts folder using for imgburn.
    Jun 2007
    Pakistan
    Thanks i created the image it solved my problem.
    i created once before but what i did wrong is create the image using video_ts as root creates an iso named video_ts.iso. now i use c:\flimname\video_ts which creates an iso named flimname.iso.
    and that runs fine thanks.
