I've searched high and low for a way to convert my avi files to SMV, using the usual Video2SMV variants and have had no luck whatsoever.
Help!
I have, it doesn't work, soon as I hit convert i seeme to do about 1 sec and says complete
The problem is most likely one of codecs. The converter doesn't like either the video or audio codec of the source. I have an AMV converter that has the same issue. I am fortunate that mine will accept avs (avisynth) files, so I can usually knock up a small script to load the video. You could try this first. If your converter won't accept an avisynth script, you might try converting the video and audio to something the converter will accept.
Start by posting a g-spot screenshot of the offending video.Read my blog here.
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 09:12 -
Batch conversion of large numbers of DV-AVi to Xvid/Divx
By snehne in forum Video ConversionReplies: 2Last Post: 19th May 2009, 18:04 -
.divx to .avi XviD conversion?
By Benhermies in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2009, 19:15 -
My Conversion Dilemma for PS3 Xvid -> DivX and MKV -> AVI
By Alterego in forum Video ConversionReplies: 0Last Post: 30th Mar 2008, 04:10 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 5Last Post: 14th Oct 2007, 12:09
