Hi
I am looking for a video editor, basically for clipping and cropping, which would work on most of the file types including
flv and swf (if possible) and which would cut/split the video without the need for re-encoding. I have an old version of VideoRedo but that does not seem to accept quite a few file types.
Anything which is simple and easy to use
thanks !
Results 1 to 9 of 9
I don't think you will find one video editor that will accept most file types. Formats like XVID, FLV, MPEG, WMV, or RM all pretty much need different editing setups.
Cuts and pastes shouldn't need re-encoding with most formats, but cropping, resizing, transitions, or filtering will. VideoReDo is a MPEG editor. VirtualDub can accept quite a few formats with the proper plugins, but the output is restricted to AVI type formats.
Most of the available editors available are listed in our tools section.
Which codecs (Formats) are you primarily working with? -
I found the tmpgenc 4 express is accepting most of the the files and it is also doing a good job of cutting and cropping. I would like to try virtualdub (Ihave used it) but where are all the plugins ? are they at one place ? thanks.
If you go to our VirtualDub toolpage, right below the program downloads:
For filter plugins: http://www.thedeemon.com/VirtualDubFilters/ AND http://neuron2.net/ are two places to look.Other info:
Download fccHandlers Virtualdub MPEG2 Plugin and WMV Plugin here, open mpeg2 and wmv directly in Virtualdub.
Download MOV,MP4 Virtualdub import plugin here.
Download FLV Virtualdub import plugin here
You can also use simple AVIsynth scripts to feed formats like RM into Virtualdub. -
HI again.
I have put the wmv plugin downloaded from the above mentioned site into the plugin folder of virtualdub but when I try to import wmv file to edit it, it shows missing codec error in its window ? what do to now pls ? -
Originally Posted by redwudz
hey,why's the output avi file from virtualdub so large? i mean 6 GB for a 10min film is insane! Am I doing something wrong? -
Try Avidemux instead of virtualdub. You don't have to worry about installing codec plugins which don't even work lol. I had the same problem with virtualdub. Installed the codec plugin package as instructed and still won't open wmv, flv, etc. Stupid piece of crap! Try Avidemux, it's a lot less snobby.
Need suggestion: free software for MP4 cropping, clipping, & watermarking?
By avideodummy in forum EditingReplies: 2Last Post: 20th Jan 2012, 09:52 -
Lossless cropping tool?
By mpalm887 in forum Video ConversionReplies: 4Last Post: 24th May 2009, 08:44 -
cropping flv video tool
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2008, 23:25 -
Cropping avi tool needed
By rindless in forum Video ConversionReplies: 6Last Post: 29th Aug 2007, 02:18 -
recommended cropping tool
By marcopolo1 in forum EditingReplies: 7Last Post: 26th Aug 2007, 04:25
