I started ripping movies to my hard drive using DVD Decrypter and I'm using AutoGK to compress them, however, the last 2 movies I've done have come out all blotchy with the video... Like there are constant distortions with it that pop up such as boxes and bars if that makes sense. I've tried redoing them a bunch of times, even uninstalled AutoGK and re installed it, and I've done it at different quality settings but the same thing happens. Any Idea as to what's wrong?
Hi-
Not right off the bat. However, this sounds to me like a corrupted source. Have you checked the source VOB files thoroughly to make sure the problem isn't with them?Any Idea as to what's wrong?
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
Video Duration & Compression Problem
By OllyPomm in forum Video ConversionReplies: 7Last Post: 31st Jan 2010, 03:03 -
Problem With Compression
By 360Spider in forum EditingReplies: 2Last Post: 22nd Mar 2009, 15:53 -
So many Video Codecs to comprehend; best Video compression?
By bulava in forum Video ConversionReplies: 7Last Post: 3rd Mar 2009, 16:01 -
Problem with Video after compression
By WuPhilly in forum Video ConversionReplies: 3Last Post: 21st May 2008, 10:58
