    Apr 2006
    Grenada
    I have 2 files with the extension .001 and 002 how do i join the file. it is supposed to be a zip file
    How's My English?
    USA
    More likely a RAR file. Try WinRAR. Some files are RAR'd and Zipped, apparently in a effort to hide their true identity. Be cautious of trojans or other malware with those type of files.
    RAR files usually have a lot more than two parts, though. Those numbers don't look like the extension, just part of the name. Do you have 'Hide extensions from known file types' unchecked in 'Folder Options'? Otherwise, you may not be seeing the true extension. If you do have it unchecked, you could always try changing the extension to .zip and see if they will open if you really think they are Zip files.
    Apr 2006
    Grenada
    it is zipped. I know there is something called a splitter that normally sets the files like that with the zip.001 and zip.002. there is normally a program that brings the 2 files together that allows you to extract the data
    How's My English?
    Jan 2003
    India
    files with such extensions are simply split binary files.
    One of the progs which can do both split and join is HJSplit
    http://freebyte.com/hjsplit/
    Have used it for years.
    Apr 2006
    Grenada
    thanks alot
    How's My English?
