I took my old analog movies and converted them to DVD's using a Panasonic DMR-ES35V. As they are long and boring I would like to edit them. When I tried to load it into the movie maker program - it could not except or recognize the .VOB, .BUO or .INF files. I have downloaded many a free software to try and convert the files to no avail.Is there something one can purchase to do this? Key is easy as I am not that adept at this. I don't necessarily need to use the movie maker program I have. Any help would be appreciated - please make explanation simple. Thanks.
				Results 1 to 11 of 11
	Extract to a MPEG>MPEG Editor>DVD Authoring program>Burn to disc.
 Extract as one large MPEG file with VOB2MPG
 Edit with a program like MPEG StreamClip
 Author with a program like GUI for dvdauthor or DVDAuthorgui for even simpler.
 Burn to DVD with ImgBurn
 Those are four freeware programs you could use. They all have guides at the bottom of their tool pages. It seems complicated the first time, but after a couple of times, very easy.
 That's one way to do it.
 And welcome to our forums.
	Thank you for your help. Spent the last 6 hours or so trying this and it did not work. I converted the file with the VOB2MPG. Couldn't find it for a while. When I did it would not play in the programs I had. Could get onto the MPEG StreamClip website. Also downloaded the other files you suggested. Then my computer told me it didn't have enough memory to play or do anything. Thank you so much for trying. I'm walking away now. Very frustrated and not happy. But that has nothing to do with the advice, just my inability to do this. Again thank you so very much for trying.
	Two fo the simplest mpeg editors are Womble Mpeg Wizard and VideoRedo. Videoredo is a simple assemble editor (basic cuts and edits) while Womble uses a more traditional non-linear timeline with transitions etc. Neither will put Vegas or Premiere out of business, but for what they do, they are solid tools.
 I have never had VOB2MPG produce footage that could not be read elsewhere, although it is a simple tool, so I can't imagine how you could use it incorrectly.
 Your other option would be VOBMerge to create a single large VOB, then edit that in VideoRedo or Womble.Read my blog here.
	Two guesses for your problems -Originally Posted by VSE
 1. you don`t have an MPG2 codec installed , although you could make a mpg2 from the dvd , you wouldnt be able to read it . If you are using Movie Maker , as recall it can`t use mpg2`s . Others have given examples of programs to use to edit the mpgs .
 2. your hard drive is full and reducing your virtual memory available - giving you "not enough memory" errors , you`ll need free space above the 4 gig for copying one DVD into an mpg . Then upto another 4 gig for making the dvd from the mpg as files on your hard drive
 two answers
 1.install a codec , for example - https://www.videohelp.com/tools/GPL_MPEG-1_2_Decoder
 2.free up lots of hard drive space
	What Sartori said.
 Just take it one step at a time.
 Video takes a lot of storage space. Figure, at a minimum, three times the size of the file you are working with. If you need help with adding additional hard drives or with other system type problems, let us know.
 I usually suggest free, fairly simple programs for beginners. One reason is no investment costs. Sure, there are some great payware programs to accomplish the same thing. But then you might end up with programs that may not suit your needs, and you would need to purchase even more programs. Another reason is you can achieve the same quality with freeware programs. Last and maybe most important, you will learn more using freeware programs.
 Understanding the processes and learning how to use them is the key to being able to create the best quality, most times with the least effort or time involved. Those freeware programs are created by individuals that are more interested in the hobby than the profit. And there are usually plenty of tutorials, guides, and people to help you with their use.
 Last word, I can tell you without a doubt, we have all been in your position at one time. We realize these processes are mostly incomprehensible to beginners, but once you understand how to accomplish these type of projects, the rewards are worth the effort. Good luck and don't give up. We realize these processes are mostly incomprehensible to beginners, but once you understand how to accomplish these type of projects, the rewards are worth the effort. Good luck and don't give up.
	Dear all,
 Thank you ever so much. I have downloaded your suggestions and will give it all a try. I found it hard to believe memory was a problem as I had 195 GB of hard drive space on the computer after all the downloads and conversions. Although what do I know as I am very limited at all this. Although I do agree persistence is the key, as it is with everything.
 Thank you all again for your patience, I will let you know what happens.
	How is that free space distributed? That is, do you have just one big partition as your C: drive? Or, do you have several drives and/or partitions?Originally Posted by VSE
 Since you said you didn't even know where your files were being stored, it could be that you have low disk space on your C: drive and you are using it for all your temp space. It doesn't matter if you have 195GB available in total if you send your files, temp or otherwise, to a partition with insufficient space.
 Take a close look at how you have configured your programs - especially if you simply accepted the defaults.
 -drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
 --Benjamin Franklin
	I honestly have no idea. Sorry no proficient enough on the computer to even begin to tell you.
	If you have a VOB files, no need to convert. Get Mpeg Video Wizard DVD.
 It will import VOB, you can edit, join and export DVD with menu.
  Converting MOV videos to DVD from iPhone 4SBy jpifer_nc in forum Video ConversionReplies: 4Last Post: 11th Dec 2011, 13:23
  mpg-videos 'burnable' on 'viewable' DVD-R without converting process?By video-fan in forum Authoring (DVD)Replies: 8Last Post: 12th Oct 2011, 08:03
  Problem copying DVDs to hard drive (previously copied from videos)By avz10 in forum RestorationReplies: 4Last Post: 2nd Mar 2010, 23:54
  Converting several flv videos into a single DVD video with ConvertXtoDVD4By Codonauta in forum Video ConversionReplies: 2Last Post: 17th Feb 2010, 20:31
  Converting IPOD videos to a MPEG for a DVDBy bmedlen1 in forum DVD RippingReplies: 2Last Post: 8th Feb 2008, 08:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
