I recently copied a PAL VHS for a friend, onto a DVD, using a LG Combi VHS/DVD recorder. (The original content had been copied to VHS from a Cine film)
My friend has asked if I could make a copy that she could send to her daughter in America (NTSC).
I have tried using several tools to make the conversion, but they either put a watermark on the film, or limit the output to just a few minutes.
Therefore, I am considering a different tack, to convert the files to a PC format. Is there such a thing as a format that will play on any PC or Mac, anywhere in the world, without having to install either additional players or codecs?
The DVD files are in a folder called, Video_TS, and the files seem to have a .vob extension.
I copied two films onto the DVD, one was about 20 minutes, the other aboout 45.
Any help for this very confused Newbie would be welcome
Allan
Results 1 to 15 of 15
have her send a pal copy of the dvd to the daughter. it will play on a computer with a media player. it may also play in her standalone, as many ntsc dvd players will convert pal to ntsc.
you could try convertxtodvd as there is an old free version in the tools section you may be able to set to output ntsc.--
The old free version of ConvertXtoDVD does a crappy job of converting PA to NTSC because it creates duplicate frames and a jerky result. DVD Flick has the same problem, although I believe the beta version uses the Pulldown method to convert correctly. FAVC already does this, and would be my first choice in this instance.
Read my blog here.
Originally Posted by guns1inger
I downloaded the GSpot program, it confirmed there was an audio track and the codecs were installed.
But a general scan for the list of all codecs and filters reports the following line:
ACM Base msacm.ulmp3acm ** Missing file: ulmp3acm.acm
which could be the source of the 'no sound' problem.
Is there a simple way to rectify this?
Any help appreciated
Allan
The original post is below, should anyone require additional info.
Allan -
Allan
Allan -
Try installing the AC3 ACM Decompressor
Read my blog here.
...is it possible that when I used VOB2 MPG I got a setting wrong which just recorded a 'blank' soundtrack.
Perhaps install the AC3 Filter. -
If I use the FAVC program, do I convert directly from the original disk, (with the VOB files) or do I use the MPEGS I created with VOB2MPG?
I tried to use DVD Flick, but it wants to create file sizes which are larger than the limitations imposed by my FAT 32 hard drives. Does FAVC have this problem, if so, is there an easy way to overcome this limitation?
Thanks to everyone who has helped so far.
Allan -
You should use the VIDEO_TS folder. If you do it with the MPEG file you will be encoding again and get poorer quality picture.
FAVC should output .vob files no larger than 0.99 gig which I think is ok for FAT32, but will only convert avi's..I think.
Are you trying to author a PAL dvd from a NTSC dvd source?“He who makes a beast of himself gets rid of the pain of being a man.” -
Originally Posted by thecrock
I decided to convert the MPEGS from VOB2MPG, good job I started earlier, it looks as though it will take about 2 hours to do the conversion.
As for the quality issue, the original was on Cine, and the copy looks as though someone has just projected it onto a screen and copied it with an early camcorder. So it does not look brilliant on VHS, but is of great sentimental value.
I love newsgroups, and I must admit, this is one of the best I have used.
With thanks
Allan
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47 -
convert PAL HDTV 1080i -> PAL DVD 576i
By halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 21:13
