I'm starting with DV, editing with vdub, and then I was hoping to encode to wmv from vdub but wmv codec doesn't show up in the compression dialog. Is this possible via a plugin?
Results 1 to 11 of 11
I think you might be able to with virtualdubmod. I know vdubmod opens wmv I believe. Make sure you have the latest build of it.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
DV can be imported into Windows Movie Maker, where you can save as a WMV file.
If I had a choice between Windows Movie Maker and Windows Media Encoder, I would go with WME.
It's a little more advanced, but gives you a lot more options. If you export your video from
VirtualDub as a uncompressed AVI, and audio as WAV, then WME should have no problem encoding
your video to WMV. Some audio formats, like MP3, may cause WME to fail. -
I know how to do this outside of VirtualDub. My question is if I can encode directly from vdub and avoid using other apps.
Not possible --- Avery Lee has had very good reasons to despiseMy question is if I can encode directly from vdub and avoid using other apps.
the ASF container itself and its "unimaginative" creators as well.
( http://advogato.org/article/101.html )
I have not. Mainly because I don't know what frameserving is!Originally Posted by guns1inger
Frameserving is the passing of video (and audio usually) frames from one program to antoher without saving to an intermediate file.
Frameserving from Vdub : https://www.videohelp.com/oldguides/virtualdubframeserve
Read my blog here.
Movie_LeftEye.wmv + Movie_RightEye.wmv + Polarized glasses = ?
By barelief in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Nov 2011, 15:45 -
combining WMV movie clips into one WMV clip
By blkwht240 in forum EditingReplies: 3Last Post: 5th Feb 2010, 00:41 -
Editing .wmv in Vdub
By imdaman in forum EditingReplies: 9Last Post: 9th Jan 2010, 16:09 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 09:16 -
.flv to .wmv or wmv. to mpg
By LITEONDVD in forum Video ConversionReplies: 5Last Post: 29th Jul 2007, 18:02
