  1. Hi,
    I have shooted some videos in a room where the lights not very high. The quality is good, but I see noise (like red noises in areas where the color tends to red).
    Is there a filter for avisynth that can reduce that ?
    Also, when shooting this video, the light on the windows seems to be overexposed (sunny areas are almost white). What filter can fix that( if possible) ?
    Thanks.
  2. Member Soopafresh's Avatar
    Jan 2004
    https://forum.videohelp.com/topic350682.html
    There's also one for Virtualdub. "Camcorder Color Denoise" on this page http://acobw.narod.ru/
    That will probably be impossible. Depends how badly the detail is blown out.
  3. Thanks. The camcolor denoise seems to do a very good job.
