Go to carousel? Sorry! Bad pun! I loved 'Logan's Run'! My 30 day 'trial' for SVCD encoding is just about up. Previously, there always was a newer version available, so it was no problem to get the new version, install, and away we'd go for another month. I had 2.01 and tried uninstalling, re-running the installation to reset the 30 day clock. Didn't work. After all this, still said my 30 days was up. So, found version 2.5, and all is well, except time is short. Do I go into REGEDIT and remove the TMPGEnc entries so the program doesn't know it's been installed on my system before? If not, what do I do? Thanks-Scott
http://www.vcdhelp.com/phpBB/viewtopic.php?t=69734&highlight=tmpgenc+regedit
if you are using tmpgenc plus, you can buy it soon here
http://www.pegasys-inc.com/e_main.html
What browser are you using these days?
By johns0 in forum PollsReplies: 60Last Post: 28th Aug 2012, 20:30 -
Tools not being updated as often these days
By G)-(OST in forum Off topicReplies: 5Last Post: 22nd Jul 2010, 21:44 -
What's A Good Burner These Days?
By MOVIEGEEK in forum ComputerReplies: 5Last Post: 17th Sep 2008, 22:54 -
How bad is U3 these days?
By ahhaa in forum ComputerReplies: 14Last Post: 22nd Aug 2008, 02:52 -
The PC's last days?
By Jo The Veteran in forum ComputerReplies: 8Last Post: 11th Sep 2007, 07:44
