Hello all
I've been getting this weird kind of jumpy playback on some of videos using XP's Media player. To best describe it, its almost like theres two videos playeing at once, one a little of the the side of the other with a bit of jumping or switching of some of the aspects of the videos in between.
It doesn't happen on all videos just some.
Anyone have any ides on what I could do to resolve this?
Any common features of the ones that misbehave - e.g., format, which disk they are on etc?
Well I've tried to find some but basically when it happens I can't seem to find a real commonality.
IE, I had a movie that was doing this while being streamed over the internet, so I downloaded it and it still did this, it did it in both Media Player 10.0 and the classic version, 6.4
Now just recently I opened a copied DVD to my hard drive via its IFO file and it did the same thing too. -
Then my next thought would be hardware. It could be HDD issues (such as simply being heavily fragmented), it could be also be cpu or memory. The next thing to watch is which other programs you have open when this occurs and/or what other activities your PC may be performing. You can use task manager to monitor cpu and memory usage.
Google is your Friend -
Yeah I thought about that too but I would say that one, so far this has only happened with three different videos that I can recall and I watch a lot of videos.
Second I'm pretty aware of the operations of my PC as I have to have it really well tweaked for performance for MS flight simulator so keep my Drives well defragged, and have virtually nothing running in the background, I have a lot of memory and use cCleaner and other utilities such a Ad Aware and SpyBot to keep things clean.
I also check things on a regular basis with HiJackThis too to be sure I have only what I want running from startup
Other than that and without going into all the spec, I have a machine that is more then capable enough to run the vids. -
Yeah I'm kinda leaning toward a codec problem myself, its just that tracking down issues with that can be kind of a pain so I was hoping it might be something else but as I haven't gotten anything else as a response for the problem from anyone I'm thinking that what it probably is.
Thanks for the link to that program though, when I get a chance I will definitely check it out.
Problem with divx playback from media player to TV
By mcon in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jan 2011, 11:06 -
Media Player Classic audio playback problem
By qpskfec in forum Software PlayingReplies: 2Last Post: 3rd Dec 2008, 14:09 -
Canon HV20 playback using media player
By pepeduran in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 26th Sep 2007, 20:04 -
jumpy windows media player - avi
By bufalo in forum Software PlayingReplies: 3Last Post: 27th Jul 2007, 14:07 -
video playback on media player
By andyluong99 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2007, 16:23
