Newbie here......I am trying to upload my mini Dv's onto my pc and make DVD's out of them. I am using Windows Vista. I was uploading them onto my internal hard drive with no problem. I was starting to run out of space, so I bought an external WD Mybook 500g hard drive. When I go to upload my dv onto the new hard drive, partway through the upload I get the following error message...........Import has stopped because the imported video file has reached the 4 gigabyte file-size limit supported by the current file system FAT32............. I was able to import the entire video onto my internal drive. What is going on?
Your external drive has been formatted as FAT32, which has a 4GB file size limit (pretty much what the error was telling you). This was done probably to make the drive as compatible as possible across multiple systems (PC, Mac and Linux). if you are only going to use it on your PC, reformat it as NTFS and you wont have any file size problems.
Read my blog here.
Give http://technet.microsoft.com/en-us/library/bb456984.aspx a look and see if it helps you out. I've never tried it, but apparently, you can reformat the storage type without wiping the drive.
Once you've redone your external drive, you can simply move items off your internal drive to the external storage and free up space. At least on my system, I get a speedier, more accurate transfer going to an internal drive.
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 11Last Post: 15th Dec 2021, 17:49 -
error when import subtitle in scenarist
By pcb in forum SubtitleReplies: 4Last Post: 17th Feb 2009, 05:38 -
JVC HDD Camcorder/Cyberlink power director file import error
By lonewolf_mb in forum Newbie / General discussionsReplies: 7Last Post: 29th Dec 2008, 21:53 -
Import .chp list from ChapterXtractor to Maestro error
By rbatty11 in forum Authoring (DVD)Replies: 2Last Post: 13th Aug 2007, 12:20 -
System Error. Import ISO from CDROM Drive
By rebelchic in forum Newbie / General discussionsReplies: 13Last Post: 12th Aug 2007, 04:04
