Hi.
I gather from the alltoavi website, and videohelp.com that alltoavi is suitable for converting vob files to avi. I have been using autogk (yes, I'm a newbie to this), but it's quite slow (3 hours coverting 1.3mb vob file to avi), so I thought I'd give alltoavi a go (I saw somewhere that it's quicker). Anyway, when I drop a vob into the GUI, I get an error message.
Looking around other sites, I see that most people use alltoavi for converting mkv files. Is there a known issue with alltoavi converting vob? ...or am I mistaken in thinking it's suitable for vob to avi conversion?
Much appreciated.
When all else fails, use a different tool. Take a look in the HOW TO: Convert section to get a list of tools/guides.
For what it's worth, I recommend autoGK. Of all the DVD to avi conversion tools I've tried so far, it has the best quality. Simply queue up a job (or several jobs) and let it run at night or while you are at work.Google is your Friend -
If I can ask. Why do you want to convert?
If it is for editing, there are Mpeg editors available. -
anlaoch it would be helpful if you could provide some pc specs ... belarc advisor can help you with determining pc spec info.
http://www.belarc.com/free_download.html
For me, its avidemux and multi core enabled xvid, info > https://www.videohelp.com/forum/archive/xvid-1-2-multicore-t337030.html
Dvd to avi with applicable filters, and two pass, about 1.4h
...3 hours coverting 1.3mb vob file to avi
Thanks to all who replied.
Tinker: The reason for converting is that in order to edit clips from my hdd dvd recorder (Ellion 950S), on my pc, I have to convert it to divx or xvid as these are the only formats the Ellion will accept back onto the hdd.
Bjs: Thanks for the pointer on Belarc. Here's my spec:
1.85 gigahertz AMD Athlon XP
200 gig Seagate ST320082 2AS SCSI Disk Device
Board: K7Upgrade-880 1.0
Bus Clock: 166 megahertz
512 Megabytes Installed Memory
Thanks again. -
Read my blog here.
alltoavi conversion problem after mkvmerge gui
By mazakou in forum Video ConversionReplies: 2Last Post: 1st Mar 2011, 16:30 -
Can you set alltoavi to produce a single AVI from multiple VOBs?
By benvid in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2008, 11:25 -
Trouble converting OGM to AVI in AllToAVI
By m93 in forum Video ConversionReplies: 8Last Post: 21st Jul 2008, 18:21 -
DVD to avi with alltoavi
By hilario in forum Video ConversionReplies: 8Last Post: 10th Jan 2008, 02:50 -
Converting VOB to AVI problem
By Booooom in forum DVD RippingReplies: 10Last Post: 10th Aug 2007, 21:48
