  1. Everytime I play a DVD on my computer the menu looks white. It just started doing this right after I installed Vista premium. I'm using k-lite codecs. I've attached a sample pic. The movie plays fine though, just the menu screen.
    USA
    You would need to post more information before anyone could even take a guess.
    Commercial or burned DVD? Or both? Or just some DVDs?
    Tried playing them with VLC media player? If that works, K-lite may have stuffed your codecs. It does that at times.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Mine do the same thing...sometimes....but only in Windows Mediaplayer.
  4. Banned
    Freedonia
    Mistake number 1- installing Vista.
    Mistake number 2 - installing K-lite.
  5. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Those were my first two thoughts also... although the K-Lite codec pack stuck out as # 1
  6. Commercial dvd's, Haven't tried other players.
