On a Mac discussion board, I discussed how my next door apartment neighbors have aparently broken into my Mac and examined the hard drives. This, in spite of having a router Firewall, and filesharing turned off. The possbility that they had "spliced" into my phone line came up. This seems likely, but I can't really pursue that discussion on that board. I don't know where else to ask, so I throw it out here. If you've tapped someone's DSL line, what exactly can you do with that, as far as hacking into someone's computer?
DSL is not really for networking. It lets you access the internet (with the right modem), but does not become a network.
Make sure that you have any type of remote access turned off. Check what ports are open on the router, and that you're not broadcasting to everyone.
You could simply call your service provider with your concern. I had a neighbor who had that done to them, so they called the provider, then the cops. -
If you call your ISP or the police you will bear the burden of proof.Originally Posted by DeadLily"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Actually, I just meant that *if* he finds out that they are indeed splicing in. That's an actual physical connection, so it's easy to prove/discover.
The other thing is that most DSL lines are carried on the phone lines, so you need filters for your phone. If they are spliced into your DSL, they're tapping your phone.
Most (if not all) dsl lines also need a modem and a login (username/password). Simply tapping tapping into the line will get them nothing but your phone.
For more info, go here:
http://www.privacyrights.org/fs/fs9-wrtp.htm#wt1 -
Is your DSL router a wireless router?. Do you have your connection encrypted?.
1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!! -
I'm thinking that way of hacking would be very rare for a number of reasons - too messy, over complex and way too much evidence would be generated, so the risk of getting caught would be high.
Perhaps try an isolation test - unplug everything from your phone line (including filters, phones..etc) and then call your ISP on the pretext that you were hearing noise on the line. They should then be able to tell you if any other device is still connected on your line, even if it is behind a central filter or an MDF.
Disappearing automatic car door
By freebird73717 in forum Off topicReplies: 5Last Post: 5th Sep 2009, 22:57 -
Next door internet starting to hit the nerves.......
By SE14man in forum Newbie / General discussionsReplies: 24Last Post: 28th Aug 2009, 19:22 -
I think i may have just screwed up my pc next door....
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 20th Aug 2009, 01:13 -
Legal - Apartment Complex Wants to Wire Own OTA Network
By Frank-0-Video in forum Off topicReplies: 9Last Post: 16th Feb 2009, 09:42 -
creating an out door soundstage (request for help)
By maxtrack in forum AudioReplies: 2Last Post: 5th Sep 2007, 20:50
