What has to go into a text file in order for DLP to recognize it and create chapters accordingly? What I want to do is create chapters in a DVD complaint MPEG in TMPDEnc before I import into DLP. Do I just put the places I want the chapters in a text file?
I create text files with the time in hh:mm
s:ff format (h=hour, m=minute, s=second, f=frame). One chapter point per line.
e.g.
00:00:00:00
00:04:32:10
00:07:12:23
00:15:22:00
01:56:08:12
etc.
etc.
Then select the text file when you want to import chapter points in the Movie menu.
Just make sure you Frame Index the movie if you want more accurate chapter points. -
Perfect. Thank you very much. One question. Will it be an issue if the movie is 23.976 with a 3:2 pull down?
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
How to create subtitle file from transcript text file
By amagrace in forum SubtitleReplies: 7Last Post: 8th May 2008, 11:44 -
How would I create points or chapters throughout my mp3 audio file???
By Hittz in forum AudioReplies: 5Last Post: 17th Feb 2008, 22:18 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 15:50
