Hello Group. I'm looking for a way on a Mac to find out what Codecs are used for a particular video file. This will be used as part of a script so I can't just check one by one. All I need to know is the FourCC code though the more info the better.
FFmpegX shows exactly what I want with the "info" button but I can't script this. I think ffmpeg might be able to do what I want but I haven't figured out how as of yet. Quicktime might also work but I can't find the right combination of applescript to give me the correct info.
Any advice would help so thanks. This is needed for OSX and I'm happy with command line or applescript utilities. My only limitation is that I can't use the spotlight/mddata for my systems as spotlight is disabled.
Jake
You can also have look to MediaInfo Mac.
Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
need help finding the best container/codec Format for my situation
By staeberc in forum Video ConversionReplies: 7Last Post: 17th Feb 2011, 16:42 -
Help with finding video mixing software
By jackthedj94 in forum Software PlayingReplies: 8Last Post: 26th Jun 2009, 05:27 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 00:25 -
Help finding tripod for video camera.
By vid83 in forum Newbie / General discussionsReplies: 12Last Post: 21st Mar 2009, 17:31
