Hi,
I've just read the FAQ, and there are several codecs available.
Does all have the same quality when uncompressing dv video ?
So which one is the best to use in avisynth
* DirectShowSource (works without any codec but slow when seek in video)
* ffdshow
* Canopus DV Codec
* Mainconcept DV Codec
* Panasonic DV Codec
You can also add the Cedocida DV codec to your list. When is the last time someone did a comparison? Force of habit has stuck me with the Panasonic DV Codec, but I'm not married to it. Nevertheless, I find it to be quite reliable, and it seems to work well with a lot of video software. It will be interesting to see if others in this forum have made their own comparisons.
Thanks, 2Bdecided. That link is: http://forum.doom9.org/showthread.php?t=33526 (the first of several pages.)
Edit: Oh, and there's also an updated thread that includes cedocida: http://forum.doom9.org/showthread.php?t=98847 -
Theseguides are good. but they are very technic and I don't understand.
how can I see a bad chroma upsampling ????? -
Panasonic DV codec is buggy and always converts to RGB. This loses the darkest and lightest shades within the DV data. The conversion is a waste of CPU cycles if you don't need/want it (when feeding CCE for example).
Cedocida is my favorite because it gives you a lot of control over the colorspace output and colorspace conversions.
Enlarged from the earlier link:Originally Posted by cd090580
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 14:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 20:26
