Results 1 to 19 of 19
  1. Hello. I am relatively new to streamclip but so far it works great, and I really like it. The only thing is, sometimes some of the features are locked out (the function is greyed-out in the pulldown menu).
    Specifically:
    Convert to MPEG...
    Convert to MPEG with MP2 Audio...
    Convert to Headed MPEG...
    Convert to TS
    Demux
    Everything else still works. It seems to only happen with certain files. I've searched through the user guide and googled but I still have no idea why it won't let me make an mpeg (sometimes). Any clue is great
    Info for most recent file:
    Duration: 0:43:31
    Data Size: 328.74 MB
    Bit Rate: 1.06 Mbps
    Video Tracks: DivX 4.1.2, 640 x 480, 29.97 fps, 935 kbps
    Audio Tracks: MPEG Layer-3 Audio stereo, 48 kHz, 121 kbps
    avi container
    And I am using an Intel Macbook 10.4.11
    TIA!!
  2. are you using the perian plug-in?
    Dec 2007
    Netherlands
    That's because these options are available only if the source file is MPEG-1 or MPEG-2.
  4. pixel zombie: I am using the perian plug-in. I tried going to system preferences and removing it, but i get the same result. Can't convert
    Levina: ... why would you only have the option to "convert to mpeg" if the file you're working with is already an mpeg???
  5. Originally Posted by kita
    The MPEG conversion settings allow you to switch file format between .mpeg, .vob and .ts. They also allow you to change the audio track from AC3 or PCM to MP2.
    MPEG Streamclip is an editing tool, but it cannot encode a video track to MPEG-1 or MPEG-2. You'll need to use Toast or ffmpegX to do that.
  6. yeah, i ran a bunch of files into streamclip and it looks like you're right. i assumed since streamclip can encode other formats (mov, avi, mp4, etc) that it could encode mpeg as well, especially being called "mpeg" streamclip. The function's name "convert TO mpeg" is misleading too. And like I said before, the user guide doesn't say anything useful about it.
    Thanks for the help
    Dec 2007
    Netherlands
    In the user guide, find the part that is titled "CONVERTING THE STREAM"; it may clear up a thing or two.
  8. hmm, what do you know. I was using 'find' to look for instructions on the commands i listed, so i must've jumped to the command descriptions and skipped over that part every time. But I still say "convert mpeg" would have been better than "convert to mpeg"
    Aug 2006
    VRO, VOB, and .mpg (or mpeg) files are all different types of containers for multiplexed MPEG-2 video (or sometimes MPEG-1). .ts files are transport streams for MPEG-2 video. MPEG Streamclip is converting to mpeg, but the container is being converted, rather than its video component. The confusion arises because the container and the video part of its contents are often referred to by the same name. This causes difficulty for almost everyone, but the authors of this software aren't to blame for that.
  10. Perhaps the authors could have slightly tweaked the labels on the program they worked so hard on, so that it didn't "cause difficulty for almost everyone"
    Dec 2007
    Netherlands
    Usually_quiet's observation that 'this causes difficulty for almost everyone' did not refer to MPEGStreamclip.
    Aug 2006
    Exactly. I was referring to a problem caused by people using the same name for a container as they use for its contents.
    Surely you don't expect the user interface for every program to eliminate the need to read and understand its documentation before using it. If you do, you are going to be disappointed on a regular basis.
    If one takes time to read the "Features" section at http://www.squared5.com/svideo/mpeg-streamclip-mac.html or the user documentation for MPEG Streamclip, there is no doubt that it needs some form of MPEG-2 or MPEG-1 video input to produce any of the kinds of MPEG-2 or MPEG-1 video output it's capable of. Nowhere does it imply that one can use MPEG Streamclip to get MPEG-1 or MPEG-2 video output from one of the other kinds of video input it accepts.
    Aug 2005
    Palo Alto, California USA
    You mean, the software isn't telepathic? Dang. Gotta write to the authors.
    The abbreviation "RTFM" was apparently coined for a reason.
  14. Originally Posted by usually_quiet
    If it is so commonly known, as it is known to usually_quiet, that "almost everyone" has difficulty from confusing mpeg containers for mpeg video formats simply because they have the same name (how on Earth could they make that mistake?) then maybe the authors could have anticipated that, and made the slightest extra effort to make it more clear. Which is what I was referring to.
    The documentation may not imply that MPEGStreamclip can encode other formats to mpeg. But, as I already said, since the software can encode between and to several other formats, it's not that big of a leap to think that it can encode to mpeg as well. Its function makes the implication where the documentation may not.
    And yes, I expect programs to eliminate the need to even HAVE a user manual. Manuals should be a backup. And I've rarely been disappointed. If a program is very reading-intensive, as I believe streamclip is not, I move on. It's something I call "user friendly". If a program is so counter-intuitive you have to grab the book every five seconds, that's a design flaw, or rather failure.
    As for tomlee and your "RTFM", you're the reason that they have instructions printed on boxes of toothpicks, and why grenade instructions include "throw towards the enemy". Maybe if programs were as obvious, people wouldn't have to search through 50 page instruction docs all the time to figure out what the author was thinking, because I'm not telepathic either.
    And by the way, this was ONE TINY aspect where I had a half-serious, just-mentioning, TINY complaint of an otherwise great program. What the hell is your guys' problem?? Some people need to take out the something that they have stuck up in somewhere.
    Aug 2005
    The difficulty with email is that a humorous comment can be misconstrued as a sarcastic barb from a martinet. Even with an emoticon, context and body language are absent. So, kita, sorry for your having taken offense, but there was none intended. I agree that the best-written software should need minimal documentation. That said, I do occasionally RTFM pretty much as soon as I encounter a puzzling problem. But only occasionally.
    Aug 2006
    It's unfortunate that a polite disagreement I have with you over this particular group of menu selections has now become something else. If what I said offends you so much that you have to engage in personal insults, such as the one in your last sentence, you had better not spend much time posting in the forums section. People are going to argue with you now and then. That's half the fun of being here.
  17. Well, it started to seem like you were all ganging up on me. And it was very surprising at how... passionately you and the others responded to my casual mentioning of a very small detail in the program. Your choice of words and tone also made it seem like you thought your conclusions were obvious, and mine therefore ludicrous, to the point where that last guy felt free to jump in with his two cents. And my comments were mostly directed at him anyway.
    (mostly)
    And so you know my intent, I am capable of much more abrasive language than what was used, as far as the last couple of sentences. I thought it was toned down pretty well, and an on-par response to some of life's more "charming" acronyms
  18. Member
    Aug 2006
    (mostly)
    The forum rules prohibit arguments on important topics, so all we can argue about are the little things. Happens all the time too.
    We are ALL capable of using much harsher language. Trust me, I could use some right now.
    [edit] Finally, I have no more control over what other participants will choose to write than you do. In any case, one can't predict what kinds of opinions are going to be expressed in a thread. The next poster taking a side in that discussion could just as easily have agreed with you.
  19. Originally Posted by usually_quiet
    ... Yes, but I'm sure you were still thinking it, right?
    My point was that I wasn't trying to attack anyone all that severely.
    It's not about disagreement. Your choice of words is very condescending in tone, and with a veiled sense of arrogance. After first putting up with that annoyance then tomlee's little dig, maybe well-intended but poorly timed, I guess I got offended. I responded in kind, and was rewarded with more lectures. Not to mention all this occurring AFTER I was given all the answers and the topic at hand was closed.
    Maybe next time you can not be so immediately aggressive, or if not, try making an effort to live up to your name :P
