Hi I'm using tmpgenc 4.0 xpress to edit an avi file, that I only want certain parts of. So I edit it all in tmpgenc 4.0 xpress, that's fine. But the file is already encoded how I want it...so I just want to output with the same settings for video and audio just with the edit included (like direct stream copy in VirtualDub). But I can't find the equivalent in tmpgenc 4.0 xpress. Anyone help?
Cheers
TMPGEnc express is an encoder and as far as I'm aware doesn't do direct stream copy,you have to re encode to output the file you have edited.If the file is mpeg you could re edit it with the likes of video redo,womble dvd wizard,or the latest TMPGEnc mpeg editor.
Can TMPGEnc 4.7.7.307 XPress support output 5.1 Channels???
By JackyWang in forum DVD RippingReplies: 2Last Post: 17th Apr 2011, 23:37 -
Editing w/ TMPGEnc 4.0 Xpress
By JOHNTOUPS in forum EditingReplies: 7Last Post: 20th Feb 2008, 16:27 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
AVI comes upsidedown using TPMGenc 4.0 XPress for editing
By rominho in forum Newbie / General discussionsReplies: 4Last Post: 17th Jun 2007, 20:38 -
By rominho in forum EditingReplies: 0Last Post: 14th Jun 2007, 10:09
. I'll stick to
