Is it possible to lower frame rate as well as syncing it with its audio? I got a 29.980 fps file and i want to make it 25.000, is there a program that does this? i don't want to actually have to play around with the interleaving til i get it right.
Results 1 to 9 of 9
You might look into DGPulldown. You may be able to avoid audio re-encoding that way.
this killed all the quality and pretty much didn't do much good v.v
You can't pulldown to reduce a framerate, only increase it.
There is no nice way to do what you are asking. You with either end up with blended frames, or dropped frames, and which ever you end up with, the quality will suck. And you still have to deal with the audio.
Can I ask why you need to go from NTSC video to PAL ?Read my blog here.
oh no, i'm not making it into pal, i have this split video and one of them for some reason is 29.970 fps and the other is 25.000 fps...so when i combine them, the audio is messed up...
They have come from different sources. If you were planning to create a DVD out of them, you could use pulldown to bring the PAL section up to NTSC video speed without affecting audio, then have the two parts play consecutively by authoring them correctly. I wouldn't try to join them unless you can get both parts from the one source.
Read my blog here.
well out of the parts there is only one that needs to be done and that's the larger file...i'd kill a little quality to lower it down a level.
Changing audio frame rate?
By architectofpain in forum AudioReplies: 22Last Post: 5th Apr 2013, 10:27 -
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 02:32 -
Frame rate fore converting MTS video to avi
By nicholasrumin in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 13:57 -
AutoGK : MPEG2 to Avi Frame Rate Problem
By Mokkori Chan in forum Video ConversionReplies: 6Last Post: 27th Feb 2009, 03:51 -
frame rate error apending avi with Virtualdub.
By lilith2014 in forum Newbie / General discussionsReplies: 13Last Post: 19th Aug 2007, 12:52
