I have a commercial I created in AE CS3 and I need to transfere it to a MiniDV says Comcast. Can I use my PC and a MiniDV camcorder to do that and what do I need. Any special camcorder, cards, cables, software, etc?
Thank You in advance,
Agon
So long as the file is DV.avi, WinDV can play it to your camcorder over IEEE-1394 and you can record any part of it.
If AE CS3 has a "print to DV tape" function similar to Premiere, you can do it from the timeline.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
WOW!..
That was exaclty what I needed to know. After reading the replies I went out today and bought a Canon ZR950 MiniDV and a miniDV cable. Rendered the video to AVI which was already 720x480 NTSC/DV then loaded the AVI into Premier and then used the "export to tape" function as said above and BANG!!! there it was on MiniDV cassette.
Thank You Thank You Thank You Thank You Thank You
you guys saved me alot of hassel
peace
MiniDV to PC-Video transfers, audio hear on camcorder but not PC after tran
By Cusi in forum Capturing and VCRReplies: 2Last Post: 14th Dec 2010, 22:15 -
a good MiniDv pass-through camcorder? with s-video??
By adameep in forum Capturing and VCRReplies: 3Last Post: 10th Sep 2010, 14:38 -
Looking for new minidv camcorder. Panasonic miniDV or other?
By latin trident in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2008, 16:54 -
How to copy a video segment from my DVD-Camcorder
By dark_cyber in forum EditingReplies: 6Last Post: 15th Oct 2008, 03:20 -
MiniDV Camcorder or DVD Camcorder
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Jul 2007, 18:13
