This is probably not a big deal since theres only one problematic disc so far but its bugging the heck out of me.
the disc is a verbatim +rw I burned with my sony usb 840u burner. I had watched it ok on my standalone player (phillips) & was going to copy it to a +r using the pioneer as a reader. The pioneer cant see the disk. DVD Identifier sez "Error: unable to initialize disc in time,not ready, incompatible medium installed".
The thing that bugs me is the pioneer is the only drive having trouble with this disc. I've also got a LG 855 burner that reads it fine & the sony it was burned on reads it fine.
Why would the pioneer be the only drive that cant read it? I've only had it for a short time so want to be sure there's not something flaky with it.
Some drives simply have trouble reading some discs. While all DVD media of a similar supported type (+/-R and +/-RW) should be supported by a burner that supports that type of media, it has been proven time and again not to be the case. Aside from ensuring you have the latest firmware installed, there isn't much that you can do.
Google is your Friend -
thanks for the replies.
glad to know i'm not alone pepigot1
i've since found a couple more video +rw's it cant read but it seems any +rw I feed it with backup or other computer files in it (as opposed to video files) it reads ok.
I guess I'll keep it, its still under 30 day refund from newegg, but frankly i'm much more impressed with my lg 855. -
Many of the recordable units have problems reading discs that they haven't formatted. They will often also have trouble with discs they recorded, but were then erased by another unit (such as your PC), and when you put it back into the recorder they won't recognize it.
I suggest getting discs specifically for use in your recorder.Google is your Friend -
DVD±RW is still a battlefield.
Check some drive reviews nd mostly you can find terrible results with RW media, depending on the used media/MID, rec speed and x-times of rewriting.*** Now that you have read me, do some other things. ***
Disk wont read
By rheming3 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Dec 2008, 02:03 -
I/O errors with my new Pioneer DVR-115D burner
By gshelley61 in forum ComputerReplies: 4Last Post: 12th Jul 2008, 15:25 -
Pioneer DVR-115d seen as 2 drives?
By dharmon in forum DVD & Blu-ray RecordersReplies: 1Last Post: 10th Jul 2008, 01:05 -
New Pioneer 115D audio stutters/skips badly
By Captain Satellite in forum DVD & Blu-ray WritersReplies: 27Last Post: 19th Jun 2008, 19:27 -
Pioneer DVR-115D Firmware Upgrade
By G13 in forum MacReplies: 3Last Post: 23rd Apr 2008, 02:14
